By jpcleve
#2023 i found this link http://www.snip2code.com/Snippet/194415/Webserver-for-Arduino-ESP8266 tonight, and with a little tweaking, wound up with the sketch below. I finally have a working http server demo! Pretty awesome little chip.
Code: Select all//Leonardo
//Serial_ & dbgTerminal = Serial;
//HardwareSerial & espSerial = Serial1;
////UNO & M328P
//#include <SoftwareSerial.h>
//SoftwareSerial dbgTerminal(10, 11); // RX, TX
//HardwareSerial & espSerial = Serial;
////MEGA2560
HardwareSerial & dbgTerminal = Serial;
// set pin numbers:
const int ledPin =  13;      // the number of the LED pin
const int ESP8266_CHPD = 4;
// Variables will change:
int ledState = HIGH;             // ledState used to set the LED
#define BUFFER_SIZE 128
char buffer[BUFFER_SIZE];
  pinMode(ledPin, OUTPUT);
  //pinMode(ESP8266_CHPD, OUTPUT);
  dbgTerminal.begin(115200); // Serial monitor
  espSerial.begin(115200); // ESP8266
  //while (!dbgTerminal) {
  // ; // wait for serial port to connect. Needed for Leonardo only
  dbgTerminal.println(F("ESP8266 demo."));
  //hardReset();
  //delay(2000);
  clearSerialBuffer();
  //connect to router
  connectWiFi("SSID", "PASSWORD");
  //test if the module is ready
  dbgTerminal.print("AT : ");
  dbgTerminal.println( GetResponse("AT",1000) );
  //Change to mode 1
  dbgTerminal.print("AT+CWMODE=1 : ");
  dbgTerminal.println( GetResponse("AT+CWMODE=1",1000) );
  //set the multiple connection mode
  dbgTerminal.print(F("AT+CIPMUX=1 : "));
  dbgTerminal.println( GetResponse("AT+CIPMUX=1",1000) );
  //set the server of port 80 check "no change" or "OK"
  dbgTerminal.print(F("AT+CIPSERVER=1,8888 : "));
  dbgTerminal.println( GetResponse("AT+CIPSERVER=1,8888", 1000) );
  //set time out
  dbgTerminal.print("AT+CIPSTO=15 : ");
  dbgTerminal.println( GetResponse("AT+CIPSTO=15",1000) );
  //print the ip addr
  dbgTerminal.print(F("ip address : "));
  dbgTerminal.println( GetResponse("AT+CIFSR", 1000) );
  delay(200);
  dbgTerminal.println();
  dbgTerminal.println(F("Start Webserver"));
  digitalWrite(ledPin,ledState);
  int ch_id, packet_len;
  char *pb;
  espSerial.readBytesUntil('\n', buffer, BUFFER_SIZE);
  if(strncmp(buffer, "+IPD,", 5)==0) {
    // request: +IPD,ch,len:data
    sscanf(buffer+5, "%d,%d", &ch_id, &packet_len);
    if (packet_len > 0) {
      // read serial until packet_len character received
      // start from :
      pb = buffer+5;
      while(*pb!=':') pb++;
      pb++;
      if (strncmp(pb, "GET /led", 8) == 0) {
        dbgTerminal.print(millis());
        dbgTerminal.print(" : ");
        dbgTerminal.println(buffer);
        dbgTerminal.print( "get led from ch :" );
        dbgTerminal.println(ch_id);
        delay(100);
        if (ledState == LOW)
          ledState = HIGH;
          ledState = LOW;
        digitalWrite(ledPin, ledState);
        homepage(ch_id);
      else if (strncmp(pb, "GET / ", 6) == 0) {
        dbgTerminal.print( "get Status from ch:" );
        delay(100);
        homepage(ch_id);
  clearBuffer();
void homepage(int ch_id) {
  String Header;
  Header =  "HTTP/1.1 200 OK\r\n";
  Header += "Content-Type: text/html\r\n";
  Header += "Connection: close\r\n";
  //Header += "Refresh: 5\r\n";
  String Content;
  Content = "Hello World!";
  Content += String(ledState);
  Header += "Content-Length: ";
  Header += (int)(Content.length());
  Header += "\r\n\r\n";
  espSerial.print("AT+CIPSEND=");
  espSerial.print(ch_id);
  espSerial.print(",");
  espSerial.println(Header.length()+Content.length());
  delay(10);
  // for debug buffer serial error
  //while (espSerial.available() >0 )  {
  //  char c = espSerial.read();
  //  dbgTerminal.write(c);
  //  if (c == '>') {
  //      espSerial.print(Header);
  //      espSerial.print(Content);
  if (espSerial.find(">")) {
    delay(10);
  //  Serial1.print("AT+CIPCLOSE=");
  //  Serial1.println(ch_id);
// Get the data from the WiFi module and send it to the debug serial port
String GetResponse(String AT_Command, int wait){
  String tmpData;
  espSerial.println(AT_Command);
  delay(wait);
    tmpData += c;
    if ( tmpData.indexOf(AT_Command) > -1 )
      tmpData = "";
      tmpData.trim();
   return tmpData;
boolean hardReset() {
  String tmpData;
  digitalWrite(ESP8266_CHPD,LOW);
  delay(100);
  digitalWrite(ESP8266_CHPD,HIGH);
  delay(1000);
  while ( espSerial.available() > 0 ) {
    tmpData +=c;
    espSerial.write(c);
    if ( tmpData.indexOf("Ready") > -1 ) {
      //Serial.println("Ready");
      clearBuffer();
      return 1;
void clearSerialBuffer(void) {
    espSerial.read();
void clearBuffer(void) {
  for (int i =0;i<BUFFER_SIZE;i++ ) {
    buffer[i]=0;
boolean connectWiFi(String NetworkSSID,String NetworkPASS) {
  String cmd = "AT+CWJAP=\"";
  cmd += NetworkSSID;
  cmd += "\",\"";
  cmd += NetworkPASS;
  cmd += "\"";
  dbgTerminal.println(cmd);
  dbgTerminal.println(GetResponse(cmd,8000));
Enjoy!
John
By zikolach
#2449 Thanks for good example. I changed it a bit to force ESP to create new access point instead of joining existing one (because I have some troubles with connecting my wifi router).
Couldn't manage to get a list of existing networks (it puts module in some "busy" mode):
ready
AT+CWLAP
AT
busy now ...
////UNO & M328P
////MEGA2560
HardwareSerial & espSerial = Serial2;
// set pin numbers:
  digitalWrite(ESP8266_CHPD, HIGH);
  hardReset();
  delay(2000);
  //connect to router
  createWiFi("TEST", "123456789");
//  connectWiFi("TEST", "123456789");
  //set time out
  //print the ip addr
  delay(200);
  char *pb;
      // start from :
      pb = buffer+5;
      pb++;
        delay(100);
          ledState = HIGH;
          ledState = LOW;
        homepage(ch_id);
        delay(100);
        homepage(ch_id);
  clearBuffer();
  String Header;
  String Content;
  delay(10);
  //  if (c == '>') {
    delay(10);
  espSerial.print("AT+CIPCLOSE=");
  espSerial.println(ch_id);
  String tmpData;
  delay(wait);
  while (espSerial.available() > 0 )  {
    tmpData += c;
      tmpData = "";
      tmpData.trim();
   return tmpData;
  String tmpData;
  delay(100);
  delay(2000);
    tmpData +=c;
    if ( tmpData.indexOf("ready") > -1 ) {
      clearBuffer();
      return 1;
    espSerial.read();
    buffer[i]=0;
boolean createWiFi(String NetworkSSID,String NetworkPASS) {
    //Change to mode 2
  dbgTerminal.print("AT+CWMODE=2 : ");
  dbgTerminal.println( GetResponse("AT+CWMODE=2",1000) );
  String cmd = "AT+CWSAP=\"";
  cmd += NetworkSSID;
  cmd += "\",\"";
  cmd += NetworkPASS;
  cmd += "\",7,0";
  dbgTerminal.print(cmd);
  //  //Change to mode 1
  cmd += NetworkSSID;
  cmd += "\",\"";
  cmd += NetworkPASS;
  cmd += "\"";
