ESP8266 Arduino WebServer stops working after few refreshes
PostPosted: Mon Dec 01, 2014 3:20 pm
by dincer
I am trying to implement a simple webserver with ESP8266 module and 3.3v Arduino mini.... Prepared a dedicated pcb with AMS117 3.3v regulator... Webserver will be posting some analog sensor data to my network, connecting to my modem-router... I am using a sketch by Ray Wang @ rayshobby.net ... everything seems ok and webserver working for a while and sending data to my browser via its IP... after some refreshes (not consistent, may work for a while) it stops sending data to my browser... but I can still ping the module via IPCONFIG and see its still working... just stops data transfer to my browser... It restarts sending if I hard reset the module.. I attached my sketch for reference... any ideas?
Dincer
Code: Select all /* ====== ESP8266 Demo ======
 *   Print out analog values
 * Change SSID and PASS to match your WiFi settings.
 * The IP address is displayed to soft serial upon successful connection.
 * Ray Wang @ Rayshobby LLC
 * http://rayshobby.net/?p=9734
// comment this part out if not using LCD debug
#include <SoftwareSerial.h>
SoftwareSerial dbg(7, 8); // using pin 7, 8 for software serial
enum {WIFI_ERROR_NONE=0, WIFI_ERROR_AT, WIFI_ERROR_RST, WIFI_ERROR_SSIDPWD, WIFI_ERROR_SERVER, WIFI_ERROR_UNKNOWN};
#define BUFFER_SIZE 128
#define SSID  "YourSSID"   // change this to match your WiFi SSID
#define PASS  "YourPASS"  // change this to match your WiFi password
#define PORT  "8080"      // using port 8080 by default
char buffer[BUFFER_SIZE];
  Serial.setTimeout(5000);
  dbg.begin(9600);
  dbg.println("begin.");
  byte err = setupWiFi();
  if (err) {
    // error, print error code
    dbg.print("setup error:");
    dbg.println((int)err);
  } else {
    // success, print IP
    dbg.print("ip addr:");
    char *ip = getIP();
    if (ip) {
      dbg.println(ip);
    else {
      dbg.println("none");
    maxTimeout();
bool maxTimeout() {
  // send AT command
  Serial.print("AT+CIPSTO=0"); Serial.print("\r\n");
  if(Serial.find("OK")) {
    return true;
  } else {
    return false;
char* getIP() {
  // send AT command
  Serial.print("AT+CIFSR"); Serial.print("\r\n");
  // the response from the module is:
  // AT+CIFSR\n\n
  // 192.168.x.x\n
  // so read util \n three times
  Serial.readBytesUntil('\n', buffer, BUFFER_SIZE);
  buffer[strlen(buffer)-1]=0;
  return buffer;
  int ch_id, packet_len;
  char *pb;
  if(strncmp(buffer, "+IPD,", 5)==0) {
    // request: +IPD,ch,len:data
    sscanf(buffer+5, "%d,%d", &ch_id, &packet_len);
    if (packet_len > 0) {
      // read serial until packet_len character received
      // start from :
      pb = buffer+5;
      while(*pb!=':') pb++;
      pb++;
      if (strncmp(pb, "GET /", 5) == 0) {
        serve_homepage(ch_id);
  buffer[0] =0;
void serve_homepage(int ch_id) {
  String header = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\nConnection: close\r\nRefresh: 5\r\n";
  String content="";
  // output the value of each analog input pin
  for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
    int sensorReading = analogRead(analogChannel);
    content += "analog input ";
    content += analogChannel;
    content += " is ";
    content += sensorReading;
    content += "<br />\n";
  header += "Content-Length:";
  header += (int)(content.length());
  header += "\r\n\r\n";
  Serial.print("AT+CIPSEND=");
  Serial.print(ch_id);
  Serial.print(",");
  Serial.print(header.length()+content.length()); Serial.print("\r\n");
  if (Serial.find(">")) {
    Serial.print(header);
    Serial.print(content);
    delay(20);
  /*Serial.print("AT+CIPCLOSE=");
  Serial.println(ch_id);*/
byte setupWiFi() {
  Serial.print("AT"); Serial.print("\r\n");
  if(!Serial.find("OK")) {
    dbg.println("WIFI_ERROR_AT");
    return WIFI_ERROR_AT;
  // reset WiFi module
  Serial.print("AT+CWMODE=3"); Serial.print("\r\n");
  Serial.print("AT+RST"); Serial.print("\r\n");
  if(!Serial.find("ready")) {
    dbg.println("WIFI_ERROR_RST");
    return WIFI_ERROR_RST;
  // set mode 3
  Serial.print("AT+CWJAP=\"");
  Serial.print(SSID);
  Serial.print("\",\"");
  Serial.print(PASS);
  Serial.println("\"");
  delay(2000);
    dbg.println("WIFI_ERROR_SSIDPWD");
    return WIFI_ERROR_SSIDPWD;
  // start server
  Serial.print("AT+CIPMUX=1"); Serial.print("\r\n");
  if(!Serial.find("OK")){
    dbg.println("WIFI_ERROR_SERVER");
    return WIFI_ERROR_SERVER;
  Serial.print("AT+CIPSERVER=1,"); // turn on TCP service
  Serial.print(PORT); Serial.print("\r\n");
  dbg.println("WIFI_ERROR_NONE");
  return WIFI_ERROR_NONE;
Re: ESP8266 Arduino WebServer stops working after few refres
PostPosted: Mon Jan 12, 2015 11:45 am
by wickedweed
hi. every time the browser refreshes, one channel is used up and it will not be freed up unless you do a AT+CIPCLOSE command every time you are done with the servehomepage(). Max 5 channels and so it will time out on the fifth refresh I think.
