Programming ESP-03 with Arduino Sketch
PostPosted: Fri Jan 08, 2016 8:56 pm
by hay_barry
Hi,
I have a sketch that I can successfully load into an ESP-01. But I need a few more I/Os so I've tried to load the same to an ESP-03.
The IDE tells me that it has completed uploading but I get nothing. I've tried to upload the .bin with one of the other flashing tools, seemingly successfully, but nothing works. I can't even get a 'hello world' from the serial port on the -03.
Feeling perplexed.
Any hints from wiser headds please?
Cheers
Re: Programming ESP-03 with Arduino Sketch
PostPosted: Sat Jan 09, 2016 11:37 am
by martinayotte
What is your wiring ?
The RES/CH_PD/GPIO2/GPIO0 need to pullup resistors to VCC and GPIO15 needs pulldown.
PostPosted: Sat Jan 09, 2016 6:33 pm
by hay_barry
Hi,
Wiring
CH_PD Tied to VCC
GP15 Tied to Ground
GP02 Pull up to Vcc with 1k2
GP0 Pull Down to Gnd for Programming. Pull up to Vcc wiht 1k2 for Run
Reset is not normally available on ESP-03
All references I can find say this is needed to run
- Barry
PostPosted: Sat Jan 09, 2016 8:48 pm
by martinayotte
Then, it should run !
I don't have other clues, maybe defective module ...
