im getting lazy lately (getting older), so instead of etching pcb, im using adapter boards for my prototype
Explore... Chat... Share...
#define SELPIN 10 //Selection Pin
#define DATAOUT 11//MOSI
#define DATAIN 12//MISO
#define SPICLOCK 13//Clock
int readvalue;
void setup(){
//set pin modes
pinMode(SELPIN, OUTPUT);
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK, OUTPUT);
//disable device to start with
digitalWrite(SELPIN,HIGH);
digitalWrite(DATAOUT,LOW);
digitalWrite(SPICLOCK,LOW);
Serial.begin(9600);
int read_adc(int channel){
int adcvalue = 0;
byte commandbits = B11000000; //command bits - start, mode, chn (3), dont care (3)
//allow channel selection
commandbits|=((channel-1)<<3);
digitalWrite(SELPIN,LOW); //Select adc
// setup bits to be written
for (int i=7; i>=3; i--){
digitalWrite(DATAOUT,commandbits&1<<i);
//cycle clock
digitalWrite(SPICLOCK,HIGH);
digitalWrite(SPICLOCK,HIGH); //ignores 2 null bits
//read bits from adc
for (int i=11; i>=0; i--){
adcvalue+=digitalRead(DATAIN)<<i;
//cycle clock
digitalWrite(SELPIN, HIGH); //turn off device
return adcvalue;
readvalue = read_adc(1);
Serial.println(readvalue,DEC);
readvalue = read_adc(2);
Serial.println(" ");
delay(250);
