I wonder if it possible to use the ESP as server and client simultaneously for example a GET request.
(I'm using a ESP-12E on devkit1)
What I need is while working as a server and responding to requests to GET a page every i.e. 1 hour
the working code of a server is (generic)
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
/* Set these to your desired credentials. */
const char *ssid = "XXXXXXXX";
const char *password = "XXXXXXXXXXXXXXXXXX";
// Update these with values suitable for your network.
IPAddress ip(192, 168, 1, 10); //Node static IP
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
ESP8266WebServer server(80);
delay(1000);
Serial.begin(9600);
WiFi.mode(WIFI_STA);
WiFi.config(ip, gateway, subnet);
WiFi.begin(ssid, password);
Serial.println("");
Serial.print(".");
Serial.println("done");
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
server.on("/", []() {
delay(5000);
server.send(200, "text/html", webPage1 + pinstate + webPage2);
server.begin();
server.handleClient();
}and it's OK, works as it should..
now the following code is obviously WRONG (while delaying in the loop section the server doesn't respond)
const char *host = "www.example.com";
delay(1000);
Serial.begin(9600);
Serial.println("");
Serial.print(".");
Serial.println("");
delay(5000);
server.begin();
WiFiClient client;
const int httpPort = 80;
return;
// We now create a URI for the request
String url = "/";
Serial.println(url);
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
delay(10);
client.flush();
client.stop();
delay(3600000);
}is what I'm seeking doable?
https://nobugsjustfeatures.wordpress.com/
