By Hydro
#41592 Hi
I try to use esp12e (not node mcu) with DHT22. This is my setup :
GND -> GND
GPIO15 -> 10k + GND
GPIO2 -> DHT DATA
GPIO0 -> 10k + 3.3V
RST -> 10k + 3.3V
EN -> 10k + 3.3V
VCC-> 3.3V
And my code :
Code: Select all#include "DHT.h"
#define DHTPIN 2     // what digital pin we're connected to
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
char str_humi[6];
char str_temp[6];
int interval;
char piece[11];
  Serial.begin(9600);
  Serial.println("DHTxx test!");
  dht.begin();
  // Wait a few seconds between measurements.
  delay(2000);
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  if (isnan(h) || isnan(t)) {
    return;
  dtostrf(t, 4, 2, str_temp);
  dtostrf(h, 4, 2, str_humi);
    Serial.println(str_temp);
This code works well with my esp01 but with esp12e i can't read the DHT, i always have "Failed to read from DHT sensor!
I try every pin but can't get the temp, always this message or nothing at all.
Maybe i miss something ?
Thank
By stex2005
#41598 Sometimes when i'm using my DHT22 I have the same problem.
Try to check DHT's power supply and remember that if you are using a NodeMCU pin 2 is not D2.
Try to use the example code you can find in the library DHT.h on GitHub
