I have written this code to connect to website via TCP. The module is already connected to wifi
altSerial.println("AT+CIPMUX=1");
if(altSerial.find("OK"))
Serial.println("ready to go");
//create string to generate TCP connection
String cmd2 = "AT+CIPSTART=\"TCP\",\""; //make this command: AT+CIPSTART=1-4 (sometimes ommitted),"TCP","107.180.3.137",80
cmd2 += DST_IP;
cmd2 += "\",80";
altSerial.find("OK");
altSerial.println(cmd2); //send command to device
delay(1000);
unsigned long t=millis()+3000;
while( t > millis() ) {
while( altSerial.available()) {
char c=altSerial.read();
Serial.print(c);
} } Here is Serial output for above code.
Network recognized!
resetting . . . . .ready to go
AT+CIPMUX=1
OK
AT+CIPSTART="TCP","107.180.3.137",80
Link typ ERROR
Link typ ERROR
It is connecting to the internet perfect, but I cannot get the module to create a TCP connection. I have tried the other syntax ("AT+CIPSTART=4,"TCP","IP",PORT) and also using AT+CIPMUX=0 and will have same problem or no response.
Any ideas??
Thank you
