Tutorial for temperature humidity sensor is here http://iot-playground.com/2-uncategorised/15-esp8266-wifi-temperature-and-humidity-sensor
Explore... Chat... Share...
canibalimao wrote:It's possible to create an EasyIoT server on a Raspberry Pi without a ESP8266 connected to it?
I have a Raspberry Pi connected to my home network and I want to host on it an EasyIoT server, but I don't want to connect to it an ESP8266 because I just have 2 and I need to use them on 2 sensors placed arround the house.
I don't understand why I need a module and I can't only make the nodes connect to my WiFi home network...
