Temporarily I found a solution: modified the standard Makefile in 2 points:
1. Added the extra mqtt include directory:
MODULES = driver mqtt user --line 135
2. Added the extra libs
LIBS = c gcc hal phy pp net80211 lwip wpa upgrade main ssl -line 139
Explore... Chat... Share...
