CHERTS, will you have a look at my blog once?
https://esp8266mesh.wordpress.com/68-2/
I think, you may need to update certain files at your repository.
Explore... Chat... Share...
tiawild wrote:Abdullbasit wrote:tiawild wrote:Hi!
You can remove the flag "-Werror" from the makefile so as not let the compiler treating warnings as errors
OK, thank you. Now it's better ...but it still doesn't works
At about 75% it freezes with this line:Code: Select allC:\Espressif\examples\nodemcu-firmware-v1.4\app\coap/hash.c:23:(.text.coap_transaction_id+0x17): dangerous relocation: call0: call target out of range: ets_memset
collect2.exe: error: ld returned 1 exit status
tiawild wrote:Code: Select allC:\Espressif\examples\nodemcu-firmware-v1.4\app\coap/hash.c:23:(.text.coap_transaction_id+0x17): dangerous relocation: call0: call target out of range: ets_memset
flyingkiwi wrote:Did you sort this problem ?
No, I didn't
