Serial.println((unsigned long )foo,HEX);
uint32_t ff = (uint32_t)*foo;
Serial.println(ff,HEX);
(thanks for the fast help.)
Explore... Chat... Share...
int fubar(void) {
return random(100);
delay(5000);
char *foo;
foo=(char *)&fubar;
Serial.print("Addr: ");
Serial.print("Value: ");
Serial.println((byte)*(unsigned long*)foo); // <-- should not reboot here provided that foo is aligned.
Addr: 40210834
Value:
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
ReinholdHiller wrote:But it does.Addr: 40210834
Value:
wdt reset
int fubar(void) {
return random(100);
delay(5000);
char *foo;
foo=(char *)&fubar;
Serial.println((byte)*(volatile unsigned long*)foo); // <-- does not reboot here provided that foo is aligned.
