Wifi.RSSI(i) invalid argument with EclipseArduino IDE V3
Posted: Tue May 24, 2016 12:02 pm
I am using Windows EclipseArduino IDE V3
I have been beating my head against the wall for a few days with this problem. I have code which includes
Serial.print(WiFi.SSID(i));
Serial.print(WiFi.RSSI(i));
When I compile under Arduino IDE there are no errors. When I compile the exact same code under EclipseArduino IDE V3 the (i) is flagged as an error. The exact same code
Serial.print(WiFi.SSID());
Serial.print(WiFi.RSSI());
Is fine, except, of course I can't scan for more than 1 network. I did complete "clean" reinstalls of Arduino and EclipseArduino but it didn't help.
I suspect the problem is in the file "ESP8266WiFiMulti.cpp" where the compile can't figure out what
strdup() is 2 lines newAP.ssid = strdup(ssid);
I get the error - Function 'strdup' could not be resolved
It turns out that strdup is not a standard c function.
I've tried setting compiler flags but nothing seems to work. I can get rid of the problem by inserting my own version of strdup() but that might cause other issues when the library is updated.
Does anybody have any suggestions?
Thanks
Thanks
