I've followed the "How to get started with ESP8266 and Arduino IDE" and I have some communication issue with it. So my first questions should I flash the firmware? And what should i flash it with.
Thanks in advance.
Explore... Chat... Share...
Orcanbull wrote:HI AusUser,
Did you use the Correct pin configurations?, GPIO 0 low, GPIO15 LOW, GPOI2 HIGH and the RESET to be pressed before the program is flashed,
Or did you Select the ESP board in the Arduino IDE,
What error are you getting?
