void drawArc(uint16 cx, uint16 cy, uint16 radius, uint16 thickness, uint16 start)this one works fine. If I add one more argument
void drawArc(uint16 cx, uint16 cy, uint16 radius, uint16 thickness, uint16 start, uint16 end)the code gets stuck at the end of the function which called drawArc. Changing it to
typedef struct {
uint16 cx;
uint16 cy;
uint16 radius;
uint16 thickness;
uint16 start;
uint16 end;
} drawArcParams;
void drawArc(drawArcParams params)works fine. And it's also probably the better way to pass in a lot of arguments.
But just wondering where does the limitation to 5 function arguments come from?
