Wemosd1 mini max7219 dotmatrix wunderground update problem
Posted: Wed Jul 12, 2017 5:54 am
Hi, I am working on the project with esp8266(wemos d1 mini,4*8*8 max 7219 dotmatrix modül) , I am having problems updating the wunderground data. I am updating it in the first run. But I have to interrupt the energy of the circuit to update it again.Thanks.
#include <SPI.h>
#include <TimeClient.h>
//#include <Arduino.h>
#include <WundergroundClient.h>
* Arduino Geliştirme Platformu
* Facebook: https://www.facebook.com/groups/Arduino.Pic
* Youtube : https://www.youtube.com/ArduinoPicGelistirmePlatformu
* Web Site: http://arduproje.blogspot.com.tr
* ESP8266 4x8 Dot matrix Display
* Yasin EKEN
* 03/06/2017
#include <SPI.h>
#include <Wire.h>
#include "WundergroundClient.h"
#include "TimeClient.h"
const float UTC_OFFSET = 2;
const boolean IS_METRIC = true;
const String WUNDERGRROUND_API_KEY = "*********"; // Buraya WUNDERGRROUND Api Key'inızı Yazınız Yoksa Çalışmaz
const String WUNDERGRROUND_LANGUAGE = "TR";
const String WUNDERGROUND_COUNTRY = "TR";
const String WUNDERGROUND_CITY = "Abdalkuyusu"; // Buraya Bulunduğunuz İli İlk Harf Büyük Olacak Şekilde Türkçe Karakter Kullanmadan Yazınız
TimeClient timeClient(UTC_OFFSET);
WundergroundClient wunderground(IS_METRIC);
* NODEMCU PIN SPI
* CLK D5
* DIN D7
* CS D8
#define CS 15
#define MAXS 4
const char ssid[] = "****";
const char pass[] = "**********";
unsigned short maxX = MAXS * 8 - 1;
unsigned short LED[MAXS][8];
unsigned short LMAX[MAXS * 8];
unsigned short HMAX[MAXS * 8];
unsigned short stringtoshort ( String s );
void stringToDisplay ( String s , int x, int y, int t);
void max7219_init(void);
void max7219_set_br(unsigned short br);
void led_init(void);
void clear_Display(void);
void refresh_display(void);
void char2Arr(unsigned short ch, int PosX, short PosY);
void connect_to_WiFi() {
WiFi.begin(ssid, pass);
delay(100);
for (byte i = 0; i < 133; i++) {
delay(10);
stringToDisplay ("Connect to " + String(ssid) , i, 0, 800);
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
SPI.begin();
led_init();
max7219_init();
max7219_set_br(10); // 0 to 15 Ekran Parlaklığı
clear_Display();
connect_to_WiFi();
wunderground.updateConditions(WUNDERGRROUND_API_KEY, WUNDERGRROUND_LANGUAGE, WUNDERGROUND_COUNTRY, WUNDERGROUND_CITY);
wunderground.updateForecast(WUNDERGRROUND_API_KEY, WUNDERGRROUND_LANGUAGE, WUNDERGROUND_COUNTRY, WUNDERGROUND_CITY);
timeClient.updateTime();
Serial.print("wunderground.getDate()= "); Serial.println(wunderground.getDate());
IPAddress IP = WiFi.localIP();
for (byte i = 0; i < 218; i++) {
delay(10);
stringToDisplay ("IP address: " + String(IP[0]) + "." + String(IP[1]) + "." + String(IP[2]) + "." + String(IP[3]) , i, 0, 800);
int x = 0;
int y = 0;
byte oldh1;
byte oldh2;
byte oldm1;
byte oldm2;
byte h1, h2, m1, m2 = 0;
while (true) {
delay(1);
String text = "SICAKLIK:" + wunderground.getCurrentTemp() +
" HISSEDILEN:" + wunderground.getFeelsLike() +
" NEM:" + wunderground.getHumidity() +
" BASINC:" + wunderground.getPressure() +
" RUZGAR:" + wunderground.getWindSpeed() +
" UV: " + wunderground.getUV() +
// " GUNDOGUMU: " +wunderground.getSunriseTime() +
//" GUNBATİMİ: " +wunderground.getSunsetTime() +
" DURUM: " + wunderground.getWeatherText() +
" TARIH: " + wunderground.getDate() +
" " + wunderground.getForecastTitle(0);
byte h = timeClient.getFormattedTime().substring(0, 2).toInt() + 1;
byte m = timeClient.getFormattedTime().substring(3, 5).toInt();
byte s = timeClient.getFormattedTime().substring(6, 8).toInt();
if ( h > 23 ) h = 0;
stringToDisplay (text , x, 0, 400);
char2Arr (stringtoshort(String(h / 10)), 29 + x, h1);
char2Arr (stringtoshort(String(h % 10)), 23 + x, 0);
if (timeClient.getFormattedTime().substring(6, 8).toInt() % 2 == 0 )
char2Arr (stringtoshort(timeClient.getFormattedTime().substring(2, 3)), 16 + x, 0);
else
char2Arr (stringtoshort(" "), 16 + x, 0);
char2Arr (stringtoshort(String(m / 10)), 12 + x, 0);
char2Arr (stringtoshort(String(m % 10)), 6 + x, 0);
refresh_display();
if ( s > 0 && s < 5 || x < 0 || x > 0 ) {
x++;
if (x > ((int)text.length() * 6) + 40) x = -30;
#include <SPI.h>
* Yasin EKEN
* 03/06/2017
#include <SPI.h>
#include <Wire.h>
* NODEMCU PIN SPI
* CLK D5
* DIN D7
* CS D8
#define CS 15
#define MAXS 4
delay(100);
delay(10);
SPI.begin();
led_init();
max7219_init();
clear_Display();
connect_to_WiFi();
delay(10);
int x = 0;
int y = 0;
byte oldh1;
byte oldh2;
byte oldm1;
byte oldm2;
while (true) {
delay(1);
else
refresh_display();
x++;
