Using SD and FS library together causes compiler errors
PostPosted: Thu Sep 14, 2017 4:36 pm
by MikeyMoMo
I have a program which compiles and runs just fine. Full error listing, belos.
I want to use SPIFFS so I included FS.h. That's the only change and the program now gets compile errors. I am already using SD for writing long term data to an SD card. I wanted to also use SPIFFS for a file that gets updated each 10 minutes instead of putting it on the SD card. I can use the SD card if this conflict cannot be resolved.
First problem with FS.h: See the statement, below. It is actually pointing into the middle of a quoted string and complaining about
Code: Select all         if (!File_Exists) dataFile.write("Date, Temp, RH, BP\n");
invalid conversion from 'const char*' to 'uint8_t {aka unsigned char}' [-fpermissive]
Second problem with FS.h:
Code: Select allinitializing argument 1 of 'virtual size_t fs::File::write(uint8_t)' [-fpermissive]
     size_t write(uint8_t) override;
Third problem with FS.h:
Code: Select allredefinition of 'class fs::File'
 class File : public Stream
Here is the complete error file. The ONLY change was adding #include "FS.h". No code lines was added yet. Without this include, all is fine. I suspect a collision between SD and FS libraries. Will be checking, myself, but any help appreciated. This is beyond my pay grade at the moment.
Code: Select allC:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Mikey\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Mikey\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Mikey\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini:CpuFrequency=80,UploadSpeed=921600,FlashSize=4M3M -ide-version=10804 -build-path C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951 -warnings=default -build-cache C:\Users\Mikey\AppData\Local\Temp\arduino_cache_9650 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose Z:\@Mikes Files\@Programming\@Arduino\@Sketches\@ESP8266 Sketches\Temp_Humidity_Time_D1_Mini_BMP280_DHT22\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Mikey\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Mikey\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Mikey\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini:CpuFrequency=80,UploadSpeed=921600,FlashSize=4M3M -ide-version=10804 -build-path C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951 -warnings=default -build-cache C:\Users\Mikey\AppData\Local\Temp\arduino_cache_9650 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose Z:\@Mikes Files\@Programming\@Arduino\@Sketches\@ESP8266 Sketches\Temp_Humidity_Time_D1_Mini_BMP280_DHT22\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino
Using board 'd1_mini' from platform in folder: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Detecting libraries used...
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_SSD1306-master" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_SSD1306-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_BMP280_Library-master" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_SSD1306-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_BMP280_Library-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_Sensor-master" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_SSD1306-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_BMP280_Library-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_Sensor-master" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_SSD1306-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_BMP280_Library-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_Sensor-master" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266HTTPUpdateServer\src" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_SSD1306-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_BMP280_Library-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_Sensor-master" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266HTTPUpdateServer\src" "-IC:\Users\Mikey\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "nul"
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src\File.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src\SD.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src\utility\Sd2Card.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src\utility\SdFile.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src\utility\SdVolume.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\Time\DateStrings.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\Time\Time.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiClient.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiClientSecure.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiServer.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiUdp.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire\Wire.cpp
Using cached library dependencies for file: C:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp
Using cached library dependencies for file: C:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library\glcdfont.c
Using cached library dependencies for file: C:\Users\Mikey\Documents\Arduino\libraries\Adafruit_SSD1306-master\Adafruit_SSD1306.cpp
Using cached library dependencies for file: C:\Users\Mikey\Documents\Arduino\libraries\Adafruit_BMP280_Library-master\Adafruit_BMP280.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src\ESP8266WebServer.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src\Parsing.cpp
Using cached library dependencies for file: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266HTTPUpdateServer\src\ESP8266HTTPUpdateServer.cpp
Using cached library dependencies for file: C:\Users\Mikey\Documents\Arduino\libraries\DHT_sensor_library\DHT.cpp
Using cached library dependencies for file: C:\Users\Mikey\Documents\Arduino\libraries\DHT_sensor_library\DHT_U.cpp
Generating function prototypes...
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_SSD1306-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_BMP280_Library-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_Sensor-master" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266HTTPUpdateServer\src" "-IC:\Users\Mikey\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Mikey\AppData\Local\Temp\arduino_build_229951/core" -c  -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_WEMOS_D1MINI"  -DESP8266 "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\d1_mini" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src" "-IC:\Program Files (x86)\Arduino\libraries\Time" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_SSD1306-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_BMP280_Library-master" "-IC:\Users\Mikey\Documents\Arduino\libraries\Adafruit_Sensor-master" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer\src" "-IC:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266HTTPUpdateServer\src" "-IC:\Users\Mikey\Documents\Arduino\libraries\DHT_sensor_library" "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp" -o "C:\Users\Mikey\AppData\Local\Temp\arduino_build_229951\sketch\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino.cpp.o"
In file included from Z:\@Mikes Files\@Programming\@Arduino\@Sketches\@ESP8266 Sketches\Temp_Humidity_Time_D1_Mini_BMP280_DHT22\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino:19:0:
C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src/SD.h:26:7: error: redefinition of 'class fs::File'
 class File : public Stream {
In file included from Z:\@Mikes Files\@Programming\@Arduino\@Sketches\@ESP8266 Sketches\Temp_Humidity_Time_D1_Mini_BMP280_DHT22\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino:17:0:
C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/FS.h:48:7: error: previous definition of 'class fs::File'
Z:\@Mikes Files\@Programming\@Arduino\@Sketches\@ESP8266 Sketches\Temp_Humidity_Time_D1_Mini_BMP280_DHT22\Temp_Humidity_Time_D1_Mini_BMP280_DHT22.ino: In function 'void WriteDataFile()':
Temp_Humidity_Time_D1_Mini_BMP280_DHT22:646: error: invalid conversion from 'const char*' to 'uint8_t {aka unsigned char}' [-fpermissive]
C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/FS.h:54:12: error:   initializing argument 1 of 'virtual size_t fs::File::write(uint8_t)' [-fpermissive]
Multiple libraries were found for "SD.h"
 Used: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD
 Not used: C:\Program Files (x86)\Arduino\libraries\SD
Multiple libraries were found for "WiFiUdp.h"
 Used: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
 Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
Using library SPI at version 1.0 in folder: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
Using library SD at version 1.0.5 in folder: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD
Using library Time at version 1.5 in folder: C:\Program Files (x86)\Arduino\libraries\Time
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
Using library Wire at version 1.0 in folder: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire
Using library Adafruit_GFX_Library at version 1.2.2 in folder: C:\Users\Mikey\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_SSD1306-master at version 1.1.2 in folder: C:\Users\Mikey\Documents\Arduino\libraries\Adafruit_SSD1306-master
Using library Adafruit_BMP280_Library-master at version 1.0.2 in folder: C:\Users\Mikey\Documents\Arduino\libraries\Adafruit_BMP280_Library-master
Using library Adafruit_Sensor-master at version 1.0.2 in folder: C:\Users\Mikey\Documents\Arduino\libraries\Adafruit_Sensor-master
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WebServer
Using library ESP8266HTTPUpdateServer at version 1.0 in folder: C:\Users\Mikey\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266HTTPUpdateServer
Using library DHT_sensor_library at version 1.3.0 in folder: C:\Users\Mikey\Documents\Arduino\libraries\DHT_sensor_library
exit status 1
