By joe
#10334 Well, I played with this a bit.
I only have an 01 module to test with, so I can only try one pin (4=GPIO2) at the moment. No success I'm afraid.
Example:
Code: Select allgpio.mode(4, gpio.INPUT, gpio.PULLUP)
node.enablewakeup(4, "both")
node.dsleep(2000)
Pulled the pin low but no luck in waking up. If somebody with more pins wants to try on a few others and report their results, I'd be interested.
Here is the diff for node.c that adds the enablewakeup command to lua.
Code: Select alldiff --git a/app/modules/node.c b/app/modules/node.c
index 90dd0d9..a0285ac 100644
--- a/app/modules/node.c
+++ b/app/modules/node.c
@@ -387,6 +387,47 @@ static int node_compile( lua_State* L )
   return 0;
+/* testing for wakeup enable and disable */
+static int node_wakeup_enable( lua_State* L )
+  s32 pin, mode;
+  size_t sl;
+  const char *str;
+  pin = luaL_checkinteger( L, 1 );
+  MOD_CHECK_ID( gpio, pin );
+  if(pin==0)
+    return luaL_error( L, "no interrupt for D0" );
+  str = luaL_checklstring( L, 2, &sl );
+  if (str == NULL)
+    return luaL_error( L, "wrong arg type" );
+  if(sl == 2 && c_strcmp(str, "up") == 0){
+    mode = GPIO_PIN_INTR_POSEDGE;
+  }else if(sl == 4 && c_strcmp(str, "down") == 0){
+    mode = GPIO_PIN_INTR_NEGEDGE;
+  }else if(sl == 4 && c_strcmp(str, "both") == 0){
+    mode = GPIO_PIN_INTR_ANYEGDE;
+  }else if(sl == 3 && c_strcmp(str, "low") == 0){
+    mode = GPIO_PIN_INTR_LOLEVEL;
+  }else if(sl == 4 && c_strcmp(str, "high") == 0){
+    mode = GPIO_PIN_INTR_HILEVEL;
+  }else{
+  gpio_pin_wakeup_enable(pin, mode);
+  return 0;
+static int node_wakeup_disable( lua_State* L )
+  gpio_pin_wakeup_disable();
+  return 0;
 // Module function map
 #define MIN_OPT_LEVEL 2
 #include "lrodefs.h"
@@ -407,6 +448,9 @@ const LUA_REG_TYPE node_map[] =
   { LSTRKEY( "output" ), LFUNCVAL( node_output ) },
   { LSTRKEY( "readvdd33" ), LFUNCVAL( node_readvdd33) },
   { LSTRKEY( "compile" ), LFUNCVAL( node_compile) },
+  { LSTRKEY( "enablewakeup"), LFUNCVAL( node_wakeup_enable ) },
+  { LSTRKEY( "disablewakeup"), LFUNCVAL( node_wakeup_disable ) },
 // Combined to dsleep(us, option)
 // { LSTRKEY( "dsleepsetoption" ), LFUNCVAL( node_deepsleep_setoption) },
 #if LUA_OPTIMIZE_MEMORY > 0
