I've a problem during the toolchain setup. I've followed the instructions on http://www.esp8266.com/wiki/doku.php?id=setup-windows-compiler-esp8266 to setup the toolchain for the development with Visual Studio. The making process ends up with the error:
1> CC user/Debounce.c
1> CC user/sscanf.c
1> CC user/udp.c
1> CC user/user_main.c
1> CC user/xPL.c
1> CC user/xPL_Message.c
1> CC user/xPL_user.c
1> AR build/app_app.a
1> LD build/app.out
1> D:/Programme/ESP8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -LD:/Programme/ESP8266/esp_iot_rtos_sdk-master/lib -TD:/Programme/ESP8266/esp_iot_rtos_sdk-master/ld/eagle.app.v6.ld -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static -Wl,--start-group -lgcc -lhal -lphy -lpp -lnet80211 -lwpa -lmain -lfreertos -llwip -ludhcp build/app_app.a -Wl,--end-group -o build/app.out
1> FW build/app.out
1> Traceback (most recent call last):
1> File "D:/Programme/ESP8266/esptool-py.py", line 485, in <module>
1> image.entrypoint = e.get_symbol_addr("call_user_start")
1> File "D:/Programme/ESP8266/esptool-py.py", line 306, in get_symbol_addr
1> return self.symbols[sym]
1> KeyError: 'call_user_start'
1> make: *** [build/app.out] Error 1Here is my makefile:
# tnx to mamalala
# Changelog
# Changed the variables to include the header file directory
# Added global var for the XTENSA tool root
# Modified for xPL-ESP8266 Project
# Changed to use esptool-py to generate firmware images
# Added PROJECT_DIR as a common base for all ESP related stuff
# Base projects directory
PROJECT_DIR = D:/Programme/ESP8266
# Base directory for the compiler
XTENSA_TOOLS_ROOT ?= $(PROJECT_DIR)/xtensa-lx106-elf/bin
# base directory of the ESP8266 SDK package, absolute
SDK_BASE ?= $(PROJECT_DIR)/esp_iot_rtos_sdk-master
#Esptool.py path and port
ESPTOOL ?= D:/Programme/Python27/python $(PROJECT_DIR)/esptool-py.py
ESPPORT ?= COM2
# name for the target project
TARGET = app
# Output directories to store intermediate compiled files
# relative to the project directory
BUILD_BASE = build
# which modules (subdirectories) of the project to include in compiling
MODULES = user
EXTRA_INCDIR = include
# libraries used in this project, mainly provided by the SDK
LIBS = gcc hal phy pp net80211 wpa main freertos lwip udhcp
# compiler flags using during compilation of source files
CFLAGS = -Os -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -D__ets__ -DICACHE_FLASH
# linker flags used to generate the main object file
LDFLAGS = -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static
# linker script used for the above linkier step
LD_SCRIPT = eagle.app.v6.ld
# various paths from the SDK used in this project
SDK_LIBDIR = lib
SDK_LDDIR = ld
SDK_INCDIR = include include/espressif include/lwip include/lwip/ipv4 include/lwip/ipv6
# select which tools to use as compiler, librarian and linker
CC := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
AR := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-ar
LD := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
OD := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-objdump
#### no user configurable options below here
SRC_DIR := $(MODULES)
BUILD_DIR := $(addprefix $(BUILD_BASE)/,$(MODULES))
SDK_LIBDIR := $(addprefix $(SDK_BASE)/,$(SDK_LIBDIR))
SDK_INCDIR := $(addprefix -I$(SDK_BASE)/,$(SDK_INCDIR))
SRC := $(foreach sdir,$(SRC_DIR),$(wildcard $(sdir)/*.c))
OBJ := $(patsubst %.c,$(BUILD_BASE)/%.o,$(SRC)) $(patsubst %.cpp,$(BUILD_BASE)/%.o,$(SRC))
LIBS := $(addprefix -l,$(LIBS))
APP_AR := $(addprefix $(BUILD_BASE)/,$(TARGET)_app.a)
TARGET_OUT := $(addprefix $(BUILD_BASE)/,$(TARGET).out)
LD_SCRIPT := $(addprefix -T$(SDK_BASE)/$(SDK_LDDIR)/,$(LD_SCRIPT))
INCDIR := $(addprefix -I,$(SRC_DIR))
EXTRA_INCDIR := $(addprefix -I,$(EXTRA_INCDIR))
MODULE_INCDIR := $(addsuffix /include,$(INCDIR))
V ?= $(VERBOSE)
ifeq ("$(V)","1")
Q :=
vecho := @true
Q := @
vecho := @echo
endif
vpath %.c $(SRC_DIR)
define compile-objects
$1/%.o: %.c
$(vecho) "CC $$<"
$(Q) $(CC) $(INCDIR) $(MODULE_INCDIR) $(EXTRA_INCDIR) $(SDK_INCDIR) $(CFLAGS) -c $$< -o $$@
endef
.PHONY: all checkdirs flash clean
all: checkdirs $(TARGET_OUT)
$(TARGET_OUT): $(APP_AR)
$(vecho) "LD $@"
$(LD) -L$(SDK_LIBDIR) $(LD_SCRIPT) $(LDFLAGS) -Wl,--start-group $(LIBS) $(APP_AR) -Wl,--end-group -o $@
$(Q) $(OD) -h $@
$(vecho) "FW $@"
$(Q) $(ESPTOOL) elf2image $(TARGET_OUT)
$(APP_AR): $(OBJ)
$(vecho) "AR $@"
$(Q) $(AR) cru $@ $^
checkdirs: $(BUILD_DIR) $(FW_BASE)
$(BUILD_DIR):
$(Q) mkdir -p $@
firmware:
$(Q) mkdir -p $@
flash: $(TARGET_OUT)-0x00000.bin $(TARGET_OUT)-0x40000.bin
-$(ESPTOOL) --port $(ESPPORT) write_flash 0x00000 $(TARGET_OUT)-0x00000.bin 0x40000 $(TARGET_OUT)-0x40000.bin
clean:
$(Q) rm -f $(APP_AR)
$(Q) rm -f $(TARGET_OUT)
$(Q) rm -rf $(BUILD_DIR)
$(Q) rm -rf $(BUILD_BASE)
$(foreach bdir,$(BUILD_DIR),$(eval $(call compile-objects,$(bdir))))
There are no bin files created and the flashing of the device doesn't start.
Did I miss something important?
Hopefully you could help me, since I struggle with the setup now for a couple of hours.
