Preliminary openocd JTAG debugger support for Xtensa/esp8266
I've been working on adding esp8266 support to the openocd open source debugger program. Mostly this means adding Xtensa architecture support, or at least enough that esp8266 can work.
Progress is up on github: https://github.com/projectgus/openocd
Still very early days, not quite usable as a JTAG debugger yet but I think we will get there.
Current status:
Todos:
Problems with no (yet) known solution:
Help wanted! Anyone who can help debug problems or finish things off is very welcome!!
(Note: at this stage un-detailed bug reports like "it doesn't work" aren't helpful, sorry, it doesn't work particularly well for anyone right now...
JTAG Connections
I've only used an ESP-12 module as it has an exposed RESET line. I think it may be possible to use modules without exposed RESET, provided you don't configure those pins as GPIOs in your program(?)
openocd command line
Something like:
Replace the first -f argument with the config file for your JTAG interface.
If you don't want to 'make install', you can run in-place like this:
Hope this is eventually useful for some people.
. In particular I'm hoping this will be a tool to further understand the inner secret workings of the esp8266 hardware.
Current status:
- Can connect, halt, resume and single step instructions.
- Can read and write memory and registers.
- gdb kind of works - using the gdb built from the esp8266 crosstool-ng fork can attach, halt, step, view register state and assembly dump, etc. [s]>There's currently a bug that causes it to lose sync randomly after a short time and requires a reset.
.[/s] EDIT: This bug is fixed, gdb seems stable now
Todos:
- Migrated to Issues List in github
- Also migrated to Issues List in github
JTAG Connections
- JTAG Signal -> ESP8266 GPIO Pin -> JTAG Pin (standard 20 pin connector)
- TMS -> 14 -> 7
- TDI -> 12 -> 5
- TCK -> 13 -> 9
- TDO -> 15 -> 13
- RST -> RST -> 15
Something like:
openocd -f interface/ftdi/olimex-arm-usb-tiny-h.cfg -f target/esp8266.cfg
./src/openocd -f ./tcl/interface/ftdi/olimex-arm-usb-tiny-h.cfg -f ./tcl/target/esp8266.cfg
