By ocb00999
#14616 My previous post was deleted, don't know why, so post again.
I compile the firmware on cygwin on win7. I use the Xtensa tool chain.
Everything goes smooth until the last step, the cmd windows shows:
..................../sdk/esp_iot_sdk_v1.0.0/lib\libssl.a<ssl_loader.o>: In function 'ssl_obj_free':
<.irom0.text+0x4c0>: undefined reference to 'default_private_key'
Anyone know what's going on? Any help will be appreciated.
Thank you very much.
By sfranzyshen
#14645
ocb00999 wrote:My previous post was deleted, don't know why, so post again.
take a look at the esp_iot_sdk_v1.0.0/examples/IoT_Demo/include/ssl/ folder ...
unsigned char default_private_key[] =
unsigned char default_certificate[] =
and in the user_main.c file ...
#ifdef SERVER_SSL_ENABLE
#include "ssl/cert.h"
#include "ssl/private_key.h"
#else
#ifdef CLIENT_SSL_ENABLE
unsigned char *default_certificate;
unsigned int default_certificate_len = 0;
unsigned char *default_private_key;
unsigned int default_private_key_len = 0;
#endif
#endif
By ocb00999
#14670 Thank you very much. That works.
But after I burn in the firmware, when I try to establish connection with an SSL server, api.parse.com,
I see the following debug information:
Client handshake start.
Client handshake failed
Could it be because of the default cert length or default private key length too short? Not enough to contain the new downloaded cert?
#else
#endif
#endif
