By ReinholdHiller
#17240 I simply want to acces the first byte of the code, but all I get is a reboot. I'm sure I made a stupid error, but I don't see it.
Code: Select allint fubar(void) {
  return random(100);
  delay(5000);
  byte i = 7;
  char *foo;
  Serial.print("sizeof(foo): ");
  Serial.println(sizeof(foo));
  Serial.println("1111");
  foo=(char *)&i;
  Serial.print("Addr: ");
  Serial.println((unsigned long )foo,HEX);
  Serial.print("Value: ");
  Serial.println((byte)*foo);
  Serial.println("2222");
  foo=(char *)&fubar;
  Serial.println((byte)*foo);     // <-- reboots here
  delay(1000);
By jcmvbkbc
#17241
ReinholdHiller wrote:I simply want to acces the first byte of the code, but all I get is a reboot.
You can only access IRAM with aligned 4-byte reads/writes, the core does not support bytewise access.
By jcmvbkbc
#17244
ReinholdHiller wrote:So what to do? My pointer looks aligned to me...
2222
Addr: 40210834
Addr: 1000000001000010000100000110100
Value:
Read whole uint32_t words and extract bytes from them.
