-- init.lua --
--Wifi Remote light on/off switch with local switch
--for use with Openremote
-- Global Variables (Modify for your network) --
ssid = "*********"
pass = "***************"
port=2323--set port for each ESP
light=3 --GPIO0
switch=4 --GPIO2
lightstate="off"
sw=0
inInt=false
-- Configure Wireless Internet
wifi.setmode(wifi.STATION)
print('set mode=STATION (mode='..wifi.getmode()..')\n')
print('MAC Address: ',wifi.sta.getmac())
print('Chip ID: ',node.chipid())
print('Heap Size: ',node.heap(),'\n')
-- wifi config start
wifi.sta.config(ssid,pass)
-- wifi config end
---GPIO Setup---
gpio.mode(light, gpio.OUTPUT)
gpio.write(light, gpio.HIGH)-- high = off
-----mode & trig for interrupt by manual switch--
gpio.mode(switch,gpio.INT)
gpio.trig(switch, "both",swINT)
-- create a server
-- 10s time out for a inactive client
sv=net.createServer(net.TCP, 10)
-- server listen on port,
sv:listen(port,function(conn)
conn:on("receive", function(conn, pl)
if string.find(pl,"on") then
print(pl)
gpio.write(light, gpio.LOW)
lightstate="on"
if string.find(pl,"off") then
print(pl)
lightstate="off"
if string.find(pl,"sen") then
conn:send (lightstate)
end)
end)
---interrupt function
------inInt ensures interrupt not interrupted
---------timer to cover contact bounce
swINT(level)
if inInt then
return
inInt=true
tmr.delay(10000)
if (lightstate=="on") then
lightstate="off"
lightstate="on"
inInt=false
