By Ravi S Kashi
#41675 Hello Guys,
I am creating a message structure for serial communication with another MCU.
I want to create a structure with the fields packed so that I can use an union that will allow me both field access and stream access.
this can work only if I can pack the structure without padding bytes. How does one do this with CHERTS MinGW setup?
Code: Select alltypedef struct
   byte fld1;
   byte fld2;
} field_type;
typedef union
   field_type fld;
   byte             arr[2];
} packet_type;
By dkinzer
#41726
Ravi S Kashi wrote:this can work only if I can pack the structure without padding bytes. How does one do this with CHERTS MinGW setup?
Code: Select all#pragma pack(push, 1)
typedef struct
   byte fld1;
   byte fld2;
} field_type;
typedef union
   field_type fld;
   byte             arr[2];
} packet_type;
#pragma pack(pop)
