Nice to be a new Member in this Forum
I have a little Problem and hope somebody can help me here
My setup is NodeMCU Lua Board and a simple 433 Mhz reciver :
I connect vcc from reciver to 3,3V from the NodeMcu.
I connect gnd from reciver to gnd from the NodeMcu.
I connect Data from the receiver to D1 from NodeMcu .
I test this very simple code:
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
mySwitch.enableReceive(5); // This is D1
if (mySwitch.available()) {
int value = mySwitch.getReceivedValue();
if (value == 0) {
Serial.print("Unknown encoding");
} else {
Serial.print("Received ");
Serial.print( mySwitch.getReceivedValue() );
Serial.print(" / ");
Serial.print( mySwitch.getReceivedBitlength() );
Serial.print("bit ");
Serial.print("Protocol: ");
Serial.println( mySwitch.getReceivedProtocol() );
mySwitch.resetAvailable();
The Problem is: it works but not every time and the range is very low...
I think it is a Problem with Interrupt because this setup without NodeMcu and with a Arduino Board works fine with a good Range.
Is it possible that the Problem is the pinsetup on the NodeMcu Lua ? Can i set the Gpio to a Interrupt Mode or similar ?!
I hope somebody can help me out
Regards from Germany
