EasyIOT integration
EasyIOT integration
Explore... Chat... Share...
VasilijHCN wrote:Look here http://iot-playground.com/forum/suggest ... art=12#632
EasyIOT integration
the same PCB board I designed?
VasilijHCN wrote:In EasyIOT server create virtual dimmer node(3 pcs), and in iot server automation create 3 programms(these programms give possibility to interact with esp8266 dimmer) to control 3 channels R G B, then i used your code for esp8266.
For stable work i fully remowed fading function, i not 100% sure that fading cause fails, but this help fo me. More real fail reason is - if we set pwm to zero, i set minimum value to 1, and then problems disappear.
Now i can control 3 channels separately from iot web interfacethe same PCB board I designed?
Yes the same circuit, i use 3 irlz44n mosfets.
