Chat freely about anything...
By hackrid
#22 Hello,
how likely is it that this IC passes some of the important certifications? (FCC, CE, EN 300 328 1.8.1)
By RichardS
#25 Its to be seen but the IC itself may pass, but once you add it to your board/product it needs to pass again.... someone may sell a module at somepoint that has a transferable approval, but the IC I believe can not do that on its own, so it will be up to someone to sell an approved module.
By jonsmirl
#118 There is no reason to believe that you couldn't build FCC approved modules with this chip, however none of the modules I seen so far are in a form that could be approved.
FCC module guidelines https://apps.fcc.gov/eas/comments/GetPublishedDocument.html?id=208&tn=830118
Three main requirements:
1) a shield over the RF path
2) integrated antenna
3) proper labeling
The modules I've seen are meant to be incorporated into a larger design and then that larger design would go through the FCC process. Similar rules apply to CE testing.
Approved modules look like this:
By RichardS
#119 So far with the lack of docs it all looks sketchy... :-) But we will see!
Richard.
