pete_l wrote:The ADJ pin of the LM317T does not appear to be connected to anything.
Jumper missing? 47E to 47F?
Explore... Chat... Share...
Lucian Marica wrote:I am wondering if it is possible to power ESP from the 5V on the arduino, using a LM317T regulator
Lucian Marica wrote:Hello,
Arduino specifications state that 3.3V out can only deliver 50mA, lower than ESP module needs at peaks. I am wondering if it is possible to power ESP from the 5V on the arduino, using a LM317T regulator.
I plan to use it like in this schematic:
