Anyone who has a sample source code that i can use as a basis/inspiration?
Thanks!
Explore... Chat... Share...
CheapB wrote:I need to build an UDP to serial bridge without any need for an external MCU or other hardware. The UDP server is listening for a message on a specific port and when it receives it, it will pass it on to the serial port.
Thanks!
