https://github.com/anakod/Sming/releases
Explore... Chat... Share...
BssList aps;
// Will be called when WiFi station network scan was completed
void listNetworks(bool succeeded, BssList list)
if (!succeeded)
Serial.println("Failed to scan networks");
return;
aps = list;
// Will be called when WiFi station was connected to AP
void connectOk()
debugf("I'm CONNECTED");
for (int i = 0; i < aps.count(); i++)
Serial.println(aps[i].ssid);
Hello sh4d0w,
I didn't have any problems with using interrupt in Sming. I think I am using 1.0.5.
Will this simple code work for you? ( Paste into Basic_Serial e.g.)
