By Andrei Candale
#16371 Hi all.
I've been trying for some time now to compile a simple program with espressif sdk.
The error I get is the following:
Code: Select allLD build/app.out
/home/andrei/workspace/licenta/toolchain/espressif_sdk/esp8266/esp-open-sdk/sdk/lib/libmain.a(app_main.o): In function `user_uart_wait_tx_fifo_empty':
(.irom0.text+0x3e4): undefined reference to `user_init'
(.irom0.text+0x57e): undefined reference to `user_init'
collect2: error: ld returned 1 exit status
make: *** [build/app.out] Error 1
This is my code:
Code: Select all#include "ets_sys.h"
#include "osapi.h"
void user_init() {
    os_printf("SDK version: %s\n", system_get_sdk_versionn());
Some help would be greatly appreciated.
Thank you
By jcmvbkbc
#16376
Andrei Candale wrote:This is my code:
#include "osapi.h"
void user_init() {
Looks like you've put it into cpp file. Either move it to c (not cpp) file, or declare it as extern "C".
By Andrei Candale
#16379
#include "osapi.h"
void user_init() {
It is in .c file. Tried with .cpp and extern "C" but it still won't work.
By jcmvbkbc
#16381
jcmvbkbc wrote:Looks like you've put it into cpp file. Either move it to c (not cpp) file, or declare it as extern "C".
Ok, is that file compiled at all?
Can you add V=1 to your make command and share the full build log?
