sigrokBlack wrote:Hi,
I wanted to try this great project, but after flashing, there is no wifi which where I could connect to?! Can somebody help me?
You must use Telnet.
Explore... Chat... Share...
VK5OI wrote:Great stuff thanks!
I have it working fine when I test it with socket test, but I would really like to make it work bi-directionally...if that is correct?
I would like to use this to replace a serial connection with comms both ways, possibly by using a VCP (virtual comm port) driver or software.
Would this require an additional MCU or similar to handle the server/client stuff or am I missing something.
