Chat freely about anything...
By eriksl
#17528 I did use the term oldfashioned within quotes!
But the technique really is oldfashioned, I have never bought devices with RS232C connectors for over ten years (although they are available). There is really no sane reasoning to still use it.
Anyway with esp8266 + level shifter you can make those devices "wireless".
By ArnieO
#17529
VK5OI wrote:
ArnieO wrote:
VK5OI wrote:Great stuff thanks!
I have it working fine when I test it with socket test, but I would really like to make it work bi-directionally...if that is correct?
I would like to use this to replace a serial connection with comms both ways, possibly by using a VCP (virtual comm port) driver or software.
Would this require an additional MCU or similar to handle the server/client stuff or am I missing something.
It *is* a transparent bridge, with serial comms in both directions between the comuter and an MCU or similar, connected to the Rx/Tx Lines of the ESP.
Thanks ArnieO
I wonder what I am doing wrong?
I can only seem to send to the ESP via TCP. This "comes out" the UART 100%
When I try to send back the other way, nothing.
To clarify, I am using a VCP (virtual comm port) program to create a virtual port (com10) via TCP (port 23) to the ESP.
This works, and it shows the flow of data on it's status scren.
I have 1 terminal "connected" to com10
I have another terminal connected to com4 (ESP UART) which is the port I flash the ESP with.
Both ports on the same computer.
Talking to this ESP via com4 works 100% for telnet, flashing, AT commands etc.
When I send chars from the vcp terminal (com10) they show on the VCP program and "appear" at com4 terminal via ESP UART.
When I enter chars at com4 term (ESP UART) they do not show at com10 or on the VCP status page.
It seems to me they do not know where to go?
I am connected to the ESP (which is in Mode 3) via its standard AP SSID directly from my pc not via a network or router.
I apologise if this is mind numbing for you, but I have so many legacy (and new) serial devices (most TTL, NOT RS232) that would benefit from this.
Thanks in advance for any comments, I suspect the issue is that I know a little but not quite enough.
BTW, this is my first exposure to Flashing firmware etc, so it is all a bit of a learning curve.
The purpose of this firmware is that the ESP replaces USB cable / UART so that you can communicate wirelessly with for instance an Arduino. In such a setup, the ESP Rx/Tx are connected to Arduino Tx/Rx. The UART is not used. When set up properly you can for instance program the Arduino wirelessly, or monitor it wirelessly.
In your setup you seem to have a UART connected to the ESP Rx/Tx, which leaves me wondering what you are attempting to accomplish?
By VK5OI
#17532
eriksl wrote:I did use the term oldfashioned within quotes!
You are correct of course, it is old fashioned. That is why I wonder why (some) big name new radios are only equipped with TTL level comms. You can of course buy a USB to radio "programming lead" or build one, which is what most hams do.
I am trying to avoid either removing the radio from the car, taking a laptop to the car, or running a long cable to the car every time I want to reprogram the radio's memory channels.
By VK5OI
#17535
ArnieO wrote:The purpose of this firmware is that the ESP replaces USB cable / UART so that you can communicate wirelessly with for instance an Arduino. In such a setup, the ESP Rx/Tx are connected to Arduino Tx/Rx. The UART is not used. When set up properly you can for instance program the Arduino wirelessly, or monitor it wirelessly.
Thanks again for persisting..
The UART connection to the ESP now is for testing only.
When/if I get my head around this, it will work exactly as you describe, but instead of programming or monitoring an Arduino , it will be my radio (amateur radio), so I can program it without removing it from my car, or having to use a laptop etc.
I still am only getting one way comms (from VCP to ESP) the response from the terminal connected to the ESP tx/rx does not go back to the terminal running connected to the virtual com port.
I must use VCP software since I must use Radio "programming" software that can only connect to the radio via an RS232 or USB port.
