I just received my ESP8266, and wired it up.
Serial comms with terminal work ok (thru' a home-made MAX232 board and an external 3.3 supply).
I also added a decoupling cap of 10uf across the module's Vcc and ground.
Now, I can see the module on my Android.
COULD see the routers (mine, and ones in the vicinity) with the AT+CWLAP.
Could connect with my router after specifying SSID and the password.
BUT, after that, AT+CWLAP no more lists the routers around; module seems to hang with a "busy now' response to any query.
All other AT commands still work.
Wonder what is happenning? (Module is connected to my router, confirmed that using AT+CWJAP?)
Wonder how to erase my router from the module's eeprom? That might make the AT+CWLAP start listing the routers around again.
Any pointers would be highly appreciated!
