eriksl wrote:Everything I write using esptool.py starting from 0x80000 ends up on 0x00000...
Kind of expected, given that 0x80000 is 512K, which is the size of your FLASH?
Explore... Chat... Share...
jcmvbkbc wrote:eriksl wrote:Everything I write using esptool.py starting from 0x80000 ends up on 0x00000...
eriksl wrote:- irom contents are written to 0x40000 which would end up at 0x40208000 I hope (= 0x40200000 + 32 k), very strange system
jcmvbkbc wrote:eriksl wrote:- irom contents are written to 0x40000 which would end up at 0x40208000 I hope (= 0x40200000 + 32 k), very strange system
- irom contents written to 0x40000 would end up at 0x40240000. FLASH mapping is purely linear.
