By gerardwr
#24141
rvtk wrote:
gerardwr wrote:I read somewhere here to use an SDK call for getting a CPU timer, but fail to find it again. Anyone remember this post?
I found the following on https://github.com/esp8266/Arduino/blob ... ference.md:
Code: Select allESP.getCycleCount() returns the cpu instruction cycle count since start as an unsigned 32-bit. This is useful for accurate timing of very short actions like bit banging.
Does that help?
Yep that's it, thanks! I forgot where I saw it.
Will try the coming week to replace the current pulse-timing using micros() with getCycleCount and test if this makes my code more reliable in receiving 433Mhz pulse trains.
By gerardwr
#24185
gerardwr wrote:
rvtk wrote:I tried the fuzzilogic code for the reception of 433 mhz rf remotes. I didn't get the example ShowReceivedCode (RemoteSwitch) to work.
Same result here, did not work for me either. Attached my RF receiver to ESP8266-GPIO2 and changed the sketch accordingly.
Update 25-07-2015.
After installing the Latest Stable release (dated 23 jul 2015) from ESP8266-Arduino I re-tested the ShowReceivedCode (from RemoteSwitch) and this works now!!
Also tried the ShowReceivedCode example (from NewRemoteSwitch) but had no success there (yet).
