Already had Domoticz running so setting things up was actually "EASY" in my case.
Can i also use it to switch a relais from Domoticz?
Explore... Chat... Share...
tweaker wrote:Can i also use it to switch a relais from Domoticz?
danbicks wrote:Wicked interface
Is this in standard IDE?
Would love a copy if you don't mind sharing.
Great work, nice to see the ESP web interface has some sparkle
Dans
