- Fri Sep 04, 2015 12:03 am
#27771
martinayotte wrote:It seems a complex scenario to troubleshoot !
Maybe you should provide your whole code and point where it is returning a null string.
I'll try to make time this weekend to do so. I want to pull out all the "extra" code I have (sensor readings, phant posting, IR LED transmit, etc), and leave just the wifi connect, deep sleep, and http get code and see if the problem still exists, and then post that code.
You've already given me great help by giving me a workaround. Which is great... Though I always consider workarounds as "losing the battle, but winning the war." The end result is what I want, it's just not the "best way" to do it. Ya know? The best way would be to fix my code in such a way that your workaround is no longer needed.
