By cendev
#2791 I'm having problems with reaching the socket i've created on tcp client connection from other functions :/ is there a way to declare it as a global variable?
i want to use the sk:send from other functions too :/
Edit : rather than dofile("functions.lua") i used the require"functions" and it did the job.. now my functions are created while socket created and works like charm :)
By gerardwr
#2794
cendev wrote:Edit : rather than dofile("functions.lua") i used the require"functions" and it did the job.. now my functions are created while socket created and works like charm :)
Brilliant, we're going to be Lua experts yet, maybe we should read a manual ;-)
By zeroday
#2797
zeroday wrote:
xinort wrote:I'm not sure if this is the best place to ask this but I'm using the lua web server and running into a problem. I can connect but only 2 times before I get a MAX_SOCKET error. I can't figure out how to release the socket after sending the data. I've tried conn:close() but no joy. This is the lua script I'm trying to use:
Code: Select allsrv=net.createServer(net.TCP)
srv:listen(80,function(conn)
conn:on("receive",function(conn,payload)
print(payload)
door="open"
if gpio.read(8)==1 then door="open" else door="closed" end
conn:send("<h1> Door Sensor. The door is " .. door ..".</h1>")
conn:close()
end)
end)
MAX_SOCKET is 5.
A connection will closed in 180 seconds if it's inactive.
I will do more test on net module to find out why conn:close() doesn't work.
My experience is a Chrome will initiate 3 or 4 connections to host, if click on "refresh" too fast, the MAX_SOCKET is reached easily.
this bug is fixed.
now you can try your code, or below
Code: Select allsrv=net.createServer(net.TCP) srv:listen(80,function(conn)
      print(node.heap())
      door="open"
      if gpio.read(0)==1 then door="open" else door="closed" end
      end)
   conn:on("sent",function(conn) conn:close() end)
end)
By gerardwr
#2801
zeroday wrote:
this bug is fixed.
I just downloaded the latest version of the firmware and uploaded it to my ESP.
With the previous version of the firmware my ESP was rebooting when the server connection was closed. With the latest firmware I have no more unwanted reboots. So MY problem is FIXED.
Thanks zero day
Edit:
This the code for my server, based on the example from zero day:
    conn:on("receive",function(conn,payload) print(payload)
    conn:send("HTTP/1.1 200 OK\n\n")
    conn:send("<html><body>")
    conn:send("<h1>Served from GWR's ESP8266</h1><BR>")
    conn:send("NODE.CHIPID : " .. node.chipid() .. "<BR>")
    conn:send("NODE.HEAP : " .. node.heap() .. "<BR>")
    conn:send("TMR.NOW : " .. tmr.now() .. "<BR>")
    conn:send("</html></body>")
  end)
end)
This is the result in the browser:
