There was errors with the missing }, they were misplaced, but also the fact that server.begin() can't be called until the Wifi connection is ready. I've modified it accordingly and do quick tests, here is the corrected version :
const char* ssid = "DOVADO";
const char* password = "5AEDDAD24D";
const int Port = 23;
const char* host = "192.168.1.30";
unsigned long previousMillis = 0;
WiFiClient client;
WiFiServer server(23);//listen on port 23
boolean tcp_server_started = false;
delay(1000);
WiFi.begin(ssid, password);
// server.begin();
Serial.println(ssid);
Serial.println("");
void SendDataToServer() {
WiFiClient client;
if (!client.connect(host, Port)) {
else {
Serial.println("Sending ...");
client.print("TEST DATA TO MLServer\r\n");
delay(100);
/* maybe you can verify an acknowledge here, but facultative */
void loop()
if (!tcp_server_started && WiFi.status() == WL_CONNECTED) {
server.begin();
tcp_server_started = true;
if (client) {
if (client.status() == CLOSED) {
client.stop();
Serial.println("connection closed !");
if (client.available()) {
req.trim();
if (req.equals("hello")) {
client.println("Hello from ESPDuino !!!");
else if (req.equals("command2")) {
client.println("Response for Command2");
else {
client = server.available();
delay(1);
unsigned long currentMillis = millis();
if (currentMillis - previousMillis > 3000) {
previousMillis = currentMillis;
// It is time to send something here ...
SendDataToServer();
