By schufti
#30688 the one in the github isn't working since AFAIK this is the version in stable and/or staging, so he wouldn't have this issue.
see attached version for changes ...
By Daemach
#30884 Well, I've tested this multiple ways, but I still can't get this SHT21 to work. I can upload the same code to an Uno and it works perfectly. When I reconnect the sensor to the ESP I get nothing useful :/ I've got a few extra breakouts lying around. I would be happy to send one to a guru if they want to sort this out. The pressure sensor works, as does the IAQ sensor. It's just the SHT that isn't communicating :/
It looks like it's running in hold master mode on the Uno if that makes any difference... I need a better logic analyzer :/
By schufti
#30890 first it woukd be interesting if you can see the sensor with the i2c-scanner allready. For this it should not be relevant if the used library makes use of hold master mode (allthough that seems not to be supported by i2c on esp8266).
