..... looks like another dependency issue ..DHT uses float and I suspect float brings in a dependency on a math library which has a dependency on sqrt which brings in a dependency on the esp tool chain which has a dependency on ieee standards which has a dependency on a specific Iee standard 784. There may be many more hidden dependencies
The dependency below on a specific drive letter and a specific directory structure is unnerving I don't have a drive d: but I'd wager the original coder does.
d:\ivan\projects\arduinoesp\toolchain\dl\esp-newlib\build\xtensa-lx106-elf\newlib\libm\math/../../../../../newlib/libm/math/w_sqrt.c:63: undefined reference to `__ieee754_sqrt'
The arduino code being tested is DHTtester from the examples DHTtester.
Any ideas on how to get DHTtester to compile?
The compiler eror
[quote]Arduino: 1.6.5 (Windows 7), Board: "Generic ESP8266 Module, Serial, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS)"
c:/arduino/arduino-1.6.5/portable/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib\libm.a(lib_a-w_sqrt.o):(.literal+0x8): undefined reference to `__ieee754_sqrt'
c:/arduino/arduino-1.6.5/portable/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib\libm.a(lib_a-w_sqrt.o): In function `sqrt':
Error compiling.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
[/quote]
