By martinayotte
#30831 Good !
So, for the disconnect issue, you are facing that too ?
For me it is intermittent, I've got the issue maybe 5 times yesterday, and today I'm not able to reproduce it again.
But my table is full of Wifi devices, so maybe it is caused my interferences.
By derek bernsen
#30832
martinayotte wrote:Good !
Yes, I'm getting the disconnect issue every time.
I'll try and move the circuit away from the nearby routers, maybe that'll fix it.
If not, I'll try and use my other ESP-01, maybe that'll fix it.
Thank you so much for helping out!
If I can't get it to blink on disconnect even after I try those tests, I'll be back in this thread.
By derek bernsen
#32401 So I've tested it out extensively, and I've found that while it does work for the initial connect-blink part, but it does not blink on disconnect. I'll try it with a different ESP8266 version instead of the ESP-01 at some point. I did notice that none of the programs using Arduino IDE work on my ESP-01 unless I leave GPIO0 disconnected from anything after programming.
Nevertheless, thank you for your help Martin
