By Pisit
#32423 Hi I'm a newbie for esp8266.
I use esp8266 receive package from Hercules software
I send message from Hercules with UDP protocol to esp8266 only one message but Esp8266 recieve more than one message.
i try to catch the message with the wireshark on network and i saw only one.
this is my code
#include <WiFiUDP.h>
int status = WL_IDLE_STATUS;
const char* ssid = "URU-Wifi";  //  your network SSID (name)
const char* pass = "";       // your network password
unsigned int localPort = 12345;      // local port to listen for UDP packets
byte packetBuffer[512]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
WiFiUDP Udp;
void setup()
  // Open serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // setting up Station AP
  WiFi.begin(ssid);
  // Wait for connect to AP
  Serial.print("[Connecting]");
  Serial.print(ssid);
  int tries=0;
    tries++;
    if (tries > 30){
      break;
printWifiStatus();
  Serial.println("Connected to wifi");
  Serial.print("Udp server started at port ");
  Serial.println(localPort);
  Udp.begin(localPort);
int lo1 = 0;
void loop()
  int noBytes = Udp.parsePacket();
  String received_command = "";
  if ( noBytes ) {
    lo1++;
    Serial.println(lo1);
    Serial.print(millis() / 1000);
    Serial.print(":Packet of ");
    Serial.print(noBytes);
    Serial.print(" received from ");
    Serial.print(Udp.remoteIP());
    Serial.print(":");
    Serial.println(Udp.remotePort());
    // We've received a packet, read the data from it
    Udp.read(packetBuffer,noBytes); // read the packet into the buffer
    // display the packet contents in HEX
    for (int i=1;i<=noBytes;i++)
      Serial.print(packetBuffer[i-1],HEX);
      received_command = received_command + char(packetBuffer[i - 1]);
      if (i % 32 == 0)
      else Serial.print(' ');
    } // end for
    Serial.println(received_command);
    // Acknowlege package
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    Udp.write("Answer from ESP8266 ChipID#");
    Udp.print(system_get_chip_id());
    Udp.write("#IP of ESP8266#");
    Udp.println(WiFi.localIP());
    Udp.endPacket();
  } // end if
  delay(10);
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
another question
my ESP is unstable some time it response very longtime. what's happen ?
I use ESP07 model
Please help me.
ps. sorry about my grammar.
