You only need to scan and see if your access point is found then return RSSI.
I will have a play later and see if I can knock up a solution for you.
Dans
Explore... Chat... Share...
#include "ESP8266WiFi.h"
const char* ssid = "target beacon name here";
const char* password = "beacon password here if applicable";
delay(50);
pinMode(2, OUTPUT);
WiFi.mode(WIFI_STA);
WiFi.disconnect();
WiFi.begin(ssid, password);
delay(50);
int out = WiFi.RSSI();
int result = out * - 15;
//Serial.print(out);
//Serial.print(result);
digitalWrite(2, HIGH);
delay(100);
digitalWrite(2, LOW);
delay(result);
