- Thu Oct 29, 2015 7:24 pm
#32594
Barnabybear wrote:Out of intrest - what values did you get with:
Code: Select all//Serial.print(out);
//Serial.print(result);
for Serial.print(result), between 1275 and 540 was printed to the serial monitor. It was usually around 600.
The number range might have been more vast if I tested it outside over longer distances.
But serial monitor did not work at all until delay(result); was commented out.
For serial.print(out), a RSSI range was printed between negative 30 something, and negative 90 something, I don't remember
And the LED I used in place of a buzzer just flickered in a strange, non-varying pattern.
I did realize that I had my digitalWrite HIGHs and LOWs incorrectly reversed in the code, I fixed that and now the LED does not light up at all.
When I unplugged to ESP-01 from my computer, it seemed to forget the program, almost, I dunno.
It would be cool if this project was cheaper for people do, the cheapest OLED display module I could find for sale online costs $4.23 USD on gearbest.com, and I don't know if that is the correct type of module.
That's still fairly cheap, even compared to eBay pricing.
I'm very interested in the OLED display based setup, but if someone gets the earlier code I posted here working without having to connect to the AP/Beacon, that would be awesome too.
