So..I uploaded your sketch...
on "air" serial print me about 737, if I touch it about 740 and if I disconnect the A0 pin it send me 764.
Without Vcc it send me 727.
Tomorrow I try to use a tester to control voltage...
thank you!
Explore... Chat... Share...
vikingfr wrote:LM35 operates from 4V to 30V. You can't use 3.3V. If you have VUSB pin on your NodeMCU board, use it, it's the 5V from USB port. Lolin boards have this pin. I don't know Amica. 'Offical' NodeMCU doesn't have this pin.
Then you need to convert the output of the LM35 to 0-1V range. You need a voltage divisor in theorie.
But LM35 with basic wiring give 0.01V/°C. If you don't go more than 100°C, you don't need voltage divisor.
