By Luciano Jose
#34984 Hi everyone,
Like many try LUA and the arduino IDE or viceversa, now its my turn with the arduino IDE :) The examples of the libs worked fine, but I can not see how to connect between 2 esp and get a respond to the client from the server once the server got a msg from the client. I am very middle skill programmer so I copy & paste a lot and edit litle
the server code goes like:
Code: Select allvoid loop() {
  WiFiClient client = server.available();  // Check if a client has connected
  if (client==0) {
    return;
  Serial.println("");
  Serial.println("New client");
  // Wait for data from client to become available
  while (client.connected() && !client.available()) {
    delay(1);
  // Read the first line of HTTP request
  Serial.print(req);   // I recieved msg ok!
  //server.print("loco");
 // client.print("loco");
  delay(100);
and this is the basis of the client which seems to be fine:
  delay(5000);
  Serial.println(host);
  WiFiClient client;
  const int httpPort = 80;
    return;
  client.print("que onda");
  delay(10);
  while(client.available()){
    Serial.print(line);
Hope someone can give me a hand on this to keep on going, thanks for reading!
Luciano
By Luciano Jose
#35000 This is finally how I ended up
Code: Select all  // Read the first line of HTTP request
  Serial.print(req);
  client.flush();
  client.print("hear you");
  delay(200);
client
Code: Select all  client.print("you hear me?");
  delay(100);
    Serial.print(line);
  Seri
any suggestion? thanks in advance
