gerardwr wrote:zeroday wrote:WOW, You guys are genius!
It takes one, to recognize one
I like your Lua firmware, maybe the web server is a good example to show what the firmware can do. If you have thoughts or suggestions for the web server, fell free to list them here. If I manage to get the Lua script embedding in HTML working, I'll probably finish developing the web server, and concentrate on controlling ESP features with some HTML/LUA code.zeroday wrote:can a js lib from cdnjs.cloudflare.com be added? little experience in web program.
I'm no js expert myself, but considering the fact that js is executed on the browser in your PC, I imagine the (low performance) ESP will not be a bottleneck. In the example of alonewolfx2 some simple js lines adding the jquery library is used, that seems to work.zeroday wrote:: the restart issue is much likely a power problem. replace it with a good one(>500mA maybe) usually fix that.
I'll try that today. The last weeks I have lived with the required resets, but now it gets annoying.[/quote]
