Might be a PROBLEM for you now, but it's more of a worthwhile Example with some "remaining issues".
Just a thought.
Explore... Chat... Share...
gerardwr wrote:Good luck, let us know how it goes, keep posting your working code, that helps others.
-- get content of register 0xAA of device 0x77
write_reg(0x20, 0x00, 0x00) -- set bank A to output
for i=0,255 do
print("Setting bank A to value " .. i)
write_reg(0x20, 0x12, i)
tmr.delay(100000)
tmr.wdclr()
end
gerardwr wrote:I suggest that you consider to continue this topic as an EXAMPLE in the Lua Examples section.
