maba wrote:Hello
Iam looking for a library for FS1000A ore a code to send date of a DHT22 from a PRO MINI to an ESP (Arduino IDE)
Thanks a lot
MABA
Hi, I use the RCSwitch library works perfecto
Dans
Explore... Chat... Share...
maba wrote:Hello
Thanks a lot
MABA
danbicks wrote:maba wrote:Hello
Thanks a lot
MABA
Dans
danbicks wrote:Hi you could use the binary send function, convert value to Bin and send, re adjust back to required format on the other end.
mySwitch.send("000000000001010100010100");
Dans
